Winter blocking
- Diverted Income
Winter blocking
Was thinking of haul out this coming Friday. What makes the most sense, block it neutral, bow or stern high? Was thinking bow high to run water out of bilge drain on travel lift then actually blocking bow low for storage. It will be inside this year. Just wondering how to get most of the water out the easiest.
Thanks!
Thanks!
1982 Trojan F-32 w/Merc 230's
1975 Baja V-1800J w/ 502 Ford
http://missriverrat.com
- Away On Busine$$
Re: Winter blocking
Have you got a seacock at the bow, mine is on the port side. If so you want bow low, stern high.
- Diverted Income
Re: Winter blocking
Sea cock yes, drain no.
Re: Winter blocking
I block bow high and remove the plug at stern.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
- Happy Ours
Re: Winter blocking
On my F26 there is 2 seacocks one bow and one stern, i remove both for winter layup
Craig
Craig
1977 F32
1975 F26 sold
Trent Severn Waterway
1975 F26 sold
- Diverted Income
Re: Winter blocking
Does the keel water migrate out of the hidden bilge and to the stern then? Thanks!LandVF36 wrote:I block bow high and remove the plug at stern.
- ready123
Re: Winter blocking
I block bow down... Then use manual pump and shamwow to remove any excess under step ahead of V berth. I have drained and sealed my hollow keel previously but if it were open the bow down is best way to get water out IMO.
I have no stern plug and find the bow fitting to be about 1" above water level so don't use that either.
Re: Winter blocking
Bow down, use a siphon to drain the hollow keel, and pour a half gallon of plumbing antifreeze into the bilge to deal with whatever water might be left.
Re: Winter blocking
I have two plugs and both stay in. Wet vac and shamwow out anything remaining.
1989 F-32
Penetang,
Georgian Bay
Penetang,
Georgian Bay
- Diverted Income
Re: Winter blocking
Stern high it is. Should happen today. Sad day....Going to be near 80 degrees too...
Thanks for the replies.
