fuel tank replacement 1978 tri cabin
marklo154
Post by marklo154 »
Well looks like the fuel tanks are shot in my tri cabin so i`m looking for options and where to find either new or possibly used
1978 Trojan F36 Tri Cabin
Bob Giaier
Re: fuel tank replacement 1978 tri cabin
Post by Bob Giaier »
I have a 73 Tri cabin. i had a process called Renu done on my port tank 5 years ago. Just google renu fuel tank repair. I plan to have the starboard tank done next winter. I'm sure there may be other solutions, that's the way I went since it was a reasonable price to get it done and I figured I didn't have to do any refitting to get a slightly different new tank in.
marklo154
Post by marklo154 »
I had 2 newer ( less then 400 hrs ) installed over the winter 270 crusaders they run perfect at idle and out of the marina but as soon as we are running for a bit and bouncing around some the one motor starts to back fire then will start stalling. So they are figuring that there is crap in the bottom of the takes that gets stirred up once we get going .
bigdave603
Post by bigdave603 »
If the motor starts back up and runs @ 1200rpms change the fuel filters and it should fix-it. I just went thru the same problem with my F32.
Cmount
Post by Cmount »
http://speedytanks.com/
Put two mid ships tanks in my f32 last year. These guys did a great job for me. They had the drawing in stock for the tanks.
1987 Jersey Dawn
"The Other Woman II"
Cmount wrote:http://speedytanks.com/
x2
have dealt with them a couple of times. Good work and easy to deal with.
blair
Post by blair »
Hello Marklo,
Not sure how you are going to deal with your tank issue, but have you tried having the fuel "cleaned" by a filtering processer? My former slipmate had this done...they draw the fuel out, filter it twice and then replace it. Might be worth looking into before you go replacing those big tanks. I can't even imagine how you would get them out of the rear cabin!!!
In any case, I'm really glad to hear you are up and running. With all the issues you have overcome you deserve many hours on the water.
Regards,
blair
Blair
1979 Trojan Tricabin with twin 255 Mercs
11' Inflatable dingy with 4 Hp merc
On the Trent canal system at Young's Point , Clear Lake, Ontario
