F32 props
F32 props
Is anyone running 15" props on their F32, I found good deal $$ on a pair of
15X15. Not sure what it might do to the performance?
Spanish Fort, Al
Looking for 33 International
Spanish Fort, Al
15 x 15
depends on engines and transmission ratio, but 15x15 should work well.
I'm running 17x20's through direct 1:1 Velvet drives with 220HP Cummins 6BTAs @ 30 knots.
I'm running 16X15s and I need a lot more rpms at cruise compared to when I used 16X16s.
I used to cruise at 3100 rpms doing 17.5 to 18 knots with the trim tabs down. I need to turn 3350 to make the same speed with the 16X15s. My guess is the 15X15s will need about 3500 rpms to do the same speed.
The real key is wide open throttle. If you are getting around 4200 WOT, your props are perfect. If you get over 4400 or less than 4000, you need to change props.
I'm going back to the 16X16s this season.
F-32 props
I am running 15x15 props on my F32 w/351's and turn 4100 rpm at 28 knots with four full fuel tanks. perfect.
f32 props
The standard way to check for the correct prop size is to run the throttles wide open in calm water. If your RPM's are between 4000 and 4400 then they are just right. If the rpm's run below 4000 at full throttle you need to go smaller, either pitch or diameter. This will allow the engine not to lug. However, if the rpm's run above 4400 at full throttle, you need a larger prop, either pitch or diameter, or both. A full, loaded boat should run close to 4000 and a lighter, empty boat will run closer to 4400. I do not run my boats this hard at any time other than to check the correct prop size. I like to think that less strain equals longer life. Kind of like marriage.
