Good afternoon
Would anyone have any information about how to replace the front windshields on a1973 f32 Trojan Flybridge Sedan, Two of the three are cracked, or where I could get information on how to replace them.
Thanks for your advise in advance,
Marianne
Windshield Relplacing
Re: Windshield Relplacing
Subscribing to this topic. Mine aren't cracked, but they have frosted spots on the corners.
I have had thoughts on just calling a glazier since it's all flat glass.
- ready123
Frosted spots... have you tried using any of the automotive headlight scratch removal products?bjanakos wrote:Subscribing to this topic. Mine aren't cracked, but they have frosted spots on the corners.
My Starboard pane is cracked and I will be replacing it using my local automotive glazier to supply the laminated glass cut to size.
There have been a few threads about this over the past few years. Try doing some searches on the forum with keywords like +front +window +replace, or +front +window +trim (the + sign means the word has to show up in the results ... if you didn't use the + you would get every post that only has the word 'front', 'window', or 'replace' in it)
Here is one relevant hit.
http://www.trojanboats.net/wforum/viewt ... ace#p82098
