Im installing my sliding glass door frame to get a floor height for the f32 i bought .Does the metal frame just rest up on the salon roof with no wood in between? This boats interior and floor from salon back is completely disassembled, so trying to get her back together. Ill be starting a build thread after i get my "stupid questions" out of the way,lol.Thanks again!
Dan
trim around f32 sliding door?
1972 f32 (318's)
28' sailboat (fast)
zodiac (7.5 honda)
Life raft (epirb)
28' sailboat (fast)
zodiac (7.5 honda)
Life raft (epirb)
- ready123
Re: trim around f32 sliding door?
It actually sits inside a groove on the underside of roof.blackfin wrote:Im installing my sliding glass door frame to get a floor height for the f32 i bought .Does the metal frame just rest up on the salon roof with no wood in between? This boats interior and floor from salon back is completely disassembled, so trying to get her back together. Ill be starting a build thread after i get my "stupid questions" out of the way,lol.Thanks again!
Dan
I don't have any from the inside I may be back up on it this w/e and will try to take some closeups of the door top and bottom.
Do the metal corner gussets at the top corner of the frame go inside or outside? This thing is ready to screw down as soon as i figure it out. Ive been searching pics for days, its not a often photoed area! Thanks
1972 f32 (318's)
28' sailboat (fast)
zodiac (7.5 honda)
Life raft (epirb)
28' sailboat (fast)
zodiac (7.5 honda)
Life raft (epirb)
- ready123
Are you talking about angle brackets? How about some pictures of what you have till I get back to my boat.
Yeah the angle brackets. Im sure i can see glass over them now in your pic,so the brackets are on the inside. Does the frame sit right on the salon plywood floor? I have a 1/2 between the frame and the roof, so it either gets a hardwood cap or sits on something other than the plywood floor. Its rough rebuilding something you didnt take apart! Thanks again , i really appreciate your help.
Dan
Dan
1972 f32 (318's)
28' sailboat (fast)
zodiac (7.5 honda)
Life raft (epirb)
28' sailboat (fast)
zodiac (7.5 honda)
Life raft (epirb)
- ready123
My boat has a fiberglass bunk running across the floor that it sits on and is sealed top on bottom with likely Butyl-l tape.
Here is a better picture that is bigger so you can look at the top and bottom more closely. Mine is a '78 with glass aft deck..... if yours is wood, which I suspect being '72 that might be the difference. Key is sliding door is on outside and screen on the inside unlike a regular patio door!
Go here to look around my pictures, you can download any for closer inspection.... the large one of aft DSC_1273 is the one I'm trying to show you.
https://www.flickr.com/photos/trojanf32 ... 4460733201
Got it, frame sits right on the plywood floor on the older wooden deck f32's. I used a piece of aluminum angle siding to protect the plywood and act as a drip rail under the door frame. Im cleaning her up tonight and ill post some pictures in my build thread tonight. Thanks!
1972 f32 (318's)
28' sailboat (fast)
zodiac (7.5 honda)
Life raft (epirb)
28' sailboat (fast)
zodiac (7.5 honda)
Life raft (epirb)
