Where's my fresh water pump?
bjanakos
Post by bjanakos »
Sometime ago, my water system was turned into raw water system... This was fine on the great lakes, but now I am in the Gulf and I don't want sea water in my head and sinks.
I have not had much luck finding the water pump used for the head and sinks. Everything has been routed to the wash-down pump.
1978 F-32.
The Dog House
Re: Where's my fresh water pump?
Post by The Dog House »
I'm not sure about the F32. On the F26 the freshwater pump is under the V berth.
Former boat: 1971 Trojan F26
It should be close to your water tanks . Could it have been removed due to the raw water set up ?
Usual position would be under the cockpit flooring (pull the aft hatch), mounted on top of the fresh water tank that is in between the fuel tanks.
AwayOnBusine$$
Post by AwayOnBusine$$ »
As per Captainmaniac my F32 is between the fuel tanks above the water tank
F32 Fly 1975
bjanakos
Post by bjanakos »
Thanks. Can confirm it is not there. Probably removed when the washdown pump was added.
The washdown is 4 GPM and I think its a little strong for the sinks and head. I'll probably be making this my next project.
There is a pump under the galley sink. Im thinking its the shower drain. Is that on-demand? Or manual?
Diverted Income
Post by Diverted Income »
bjanakos wrote:Thanks. Can confirm it is not there. Probably removed when the washdown pump was added.
Yes. Shower drain pump should have a switch in the head. Ours is right below the switch for the fan.
1982 Trojan F-32 w/Merc 230's
1975 Baja V-1800J w/ 502 Ford
http://missriverrat.com
