As some of you know, along the way one in particular caught my wife's attention. Of course a different one caught mine. This is where a few weeks of badgering by the wife may have paid off in the end to her favor. After some not so gentle persuasion by her and my father, my mind was made up and away we went on to start our F36 Convertible project.
Where to start, I guess from where we are currently to the top priority repairs...
1973 Trojan F36 Convertible with Master and Bunk Staterooms. Partial remodel in late 80's / early 90's.
Repowered with twin 1988 Chrysler M460's with 1.91:1 Velvet 72C's. Port is standard rotation and starboard is reverse rotation. Velvet 1.91:1 reverse the coupler output so props spin correctly. 20" x 20" props with 1-3/8" shafts. Rudders horribly small for props.
Updated Kohler 6.5kW genset, Cruiseair 16k BTU A/C, Hydranautic dual helm steering package, and fresh water system.
Various patches made by PO to the systems onboard. These could potentially cause me numerous headaches down the road if I don't make the repairs before she hits the water.
Major repairs
1) Strip interior headliner due to water leaking in from screws around forward hatches.
2) Seal the three forward hatches to stop water ingress.
3) Determine cause of starboard engine not turning over by hand (previous owner had overheat issue on this engine)
4) Replace stern cockpit teak deck.
5) Replace core around three forward hatches.
6) Remove recycling head and replace with current generation head and MSD system.
7) Preventive Maintenance on port engine and both transmissions
9) Replace three batteries and associated cables. Repair / replace any other 12V system cables that are suspect from PO replacement
10) Repair / Replace 120VAC system. Preventive Maintenance on Genset.
11) Make patches to existing systems as issues arrive
12) Repair port stringer at transom (one foot of damage)
13) Replace thru hulls
14) Clean running gear, sand and paint bottom, compound and wax top sides.
15) Replace Bimini and Bridge enclosure
16) Update electronics
This list was made based on initial assessment visits. Of course Mother Nature threw in a whole slew of curve balls with this weather we are experiencing.
My list order has been modified somewhat.
To date, I have accomplished:
1) Wife said remove old head and begin stripping of headliner. I heard rip everything out all the way to the fiberglass. Found foredeck was slightly better than thought. Have three areas that will require core repair. Stripped second wallpaper application off walls. Need to soak and strip original wallpaper off walls. Demolition of cabin mostly complete.
Mid-way through tear out
2) Determine cause of starboard engine lock up. Have disassembled starboard engine down to the block. Found two bent push rods, both exhaust, one on cylinder three and one on cylinder seven. Pistons are currently stuck due to What i currently believe is just surface rust on cylinder walls. Head gasket looks good; no blow by. Heads on the way to the machine shop for Magnaflux, cleaning, and valve job.
3) Started digging through the rest of the boat to identify problem systems. Need to address D.C. System sooner than later. Same for A.C. System. Fresh water system not looking too shabby. Needs some attention.
4) Found macerator and Y-Valve under forward V-berth. Macerator literally just sitting on hull with no fasteners. Y-valve hose connections can be pulled off. Fortunately, the PO drained the system and through the miracle of science, evaporation took care of the rest. Entire head and plumbing removed. Took the liberty of stripping the rest of the "Library" for complete refit.
5) Discovered the hull portals are actually just blocks of wood with Plexiglass laminated to them. Very excited about this find as the window trim is in rather bad shape. Will add to list to repair and replace.
6) Found PO has used the standard green water hose to connect the shower drain to the diaphragm pump. They continued that thought process with white garden hose to the thru hull. Add plumbing repair / replacement to the list.
7) Found PO has installed Dometic raw water pump for forward A/C under the stairs. Due to difference in original vs replacement pump, a 90 degree galvanized elbow was installed on the plastic output tube. Of course it sits higher than the floor, so that explains why the floor hatch at the stairs rocks back and forth. Add adjustment, relocation, and repair to list.
9) Cockpit deck is plywood underlayment with teak veneer over top. Structural supports in good shape. Just a wood floor replacement. Phew.
10) Add complete fuel system plumbing replacement to list. Most is original. Copper lines in good condition. Hoses shot.
As soon as I have the chance to upload photos to web and hyper link them, I will add to the appropriate topics.
Hoping the weather is decent this weekend. I really need to seal the forward hatches.
