Cappy's f32 rehab
Captrichc
Re: Cappy's f32 rehab
Post by Captrichc »
prowlersfish wrote: Mon Apr 01, 2019 10:49 pm
Captrichc wrote: Tue Mar 26, 2019 8:18 pm . Well all of the through hull fittings are installed and siliconed back in place.
If this below the water line do not use silicone . Use something like 4200 or 5200 .
I used 5200 below water and boat life above.
1974 f32 Sedan
Twin 233 Mercruisers
Captrichc
Post by Captrichc »
Started the hatch for the deck. Cut out the plywood and the trim is cut.
1974 f32 Sedan
Captrichc
Post by Captrichc »
Hatch is glassed and gelcoated. Will trim the glass and put aluminum trim on it in the AM. I have 1 final coat of gelcoat to put on the deck and it will be complete.
1974 f32 Sedan
BradZ
Post by BradZ »
Hey Cappy lets see some more pictures
Captrichc
Post by Captrichc »
Here is the hatch.
1974 f32 Sedan
Nice work!
Captrichc
Post by Captrichc »
WayWeGo wrote: Mon Apr 08, 2019 6:07 pmNice work!
Thanks WayweGo. I have 2 handles to add then onto the boat. Once its on the boat oat i can uncover her amd start cleaning and running the electronics.
1974 f32 Sedan
rickalan35
Post by rickalan35 »
Very nice.
Captrichc
Post by Captrichc »
Thanks Rick.
1974 f32 Sedan
Captrichc
Post by Captrichc »
Just picked up the generator. Its amazing. Thank you so much Bret!!!
1974 f32 Sedan
Captrichc
Post by Captrichc »
Canvas are done. And rubber gasket is done on hatch. Pickup and exhaust are drilled and set for genny. Will do the zinks and put props on today. Add the transducer for the new simrad system. Bottom is painted. And i figured out the starter issue.
1974 f32 Sedan
Rich, you are making great progress and I am especially glad to hear you got your starter working correctly.
Captrichc
Post by Captrichc »
WayWeGo wrote: Sat Apr 13, 2019 5:45 pm Rich, you are making great progress and I am especially glad to hear you got your starter working correctly.
Yes me too. And thanks for the kind words. Moving along as best as i can. Finished 1 of the engine hatches today. Im just checking off as i go.
1974 f32 Sedan
Captrichc
Post by Captrichc »
Uncovered the boat yesterday. Not happy with the bow at all. Softer then i remember. That i will have to keep an eye on. Will definitely have to cut it all out and recore this winter. Im hoping it doesnt effect my season.
1974 f32 Sedan
Captrichc
Post by Captrichc »
Engine hatches complete. Transducer mounted. And props are put back on. Very happy at the moment. Will get some new pics this week.
1974 f32 Sedan
