fuel pump Chrysler 360
TADTOOMUCH
Post by TADTOOMUCH »
I am having problems with rough running at high RPM around 2200.
I think the fuel pump may be the issue. Runs okay at idle just a little rougher than the starboard but not bad.
Has anyone replaced their OEM Chrysler fuel pump with a new one? Do the fuel lines all line up the same or do I need to re-do those too?
Boat Name: A TAD TOO MUCH
chucka
Post by chucka »
try this forum for Chrysler fuel pump info. Lots of knowlegable people there:
http://www.marineengine.com/discus/mess ... 2490.shtml
Chuck
formerly
Lots A Luck
Trojan F-26 Express
Narragansett Bay, RI
jddens
Post by jddens »
Don't think 2200 rpm is high rpm. What happens when you open her up?
1998 Kawasaki ZXi 1100
TADTOOMUCH
RPM issue
I meant anything over 2200 rpm and she starts to sputter. at 800 rpms up until about 2100 she seems to run okay. I can't get it to run at all around 3000 or it will run out of gas and quit.
sweet E mocean
Re: RPM issue
Post by sweet E mocean »
TADTOOMUCH wrote:I meant anything over 2200 rpm and she starts to sputter. at 800 rpms up until about 2100 she seems to run okay. I can't get it to run at all around 3000 or it will run out of gas and quit.
that sounds more like an ignition breakdown to me check dist cap and wires
1978 f32
Jim
TADTOOMUCH
ignition or fuel
yea, I was also going to do some checking of the distributor, rotor, spark advance to make sure as those items are pretty cheap to replace and check. I got a new marine fuel pump on e-bay for 33 bucks so I thought I'd replace that as well and if not the problem then I'd have one for future.
