I am having problems with rough running at high RPM around 2200.
I think the fuel pump may be the issue. Runs okay at idle just a little rougher than the starboard but not bad.
Has anyone replaced their OEM Chrysler fuel pump with a new one? Do the fuel lines all line up the same or do I need to re-do those too?
fuel pump Chrysler 360
- TADTOOMUCH
Boat Name: A TAD TOO MUCH
try this forum for Chrysler fuel pump info. Lots of knowlegable people there:
http://www.marineengine.com/discus/mess ... 2490.shtml
Chuck
Chuck
formerly
Lots A Luck
Trojan F-26 Express
Narragansett Bay, RI
Lots A Luck
Trojan F-26 Express
- TADTOOMUCH
RPM issue
I meant anything over 2200 rpm and she starts to sputter. at 800 rpms up until about 2100 she seems to run okay. I can't get it to run at all around 3000 or it will run out of gas and quit.
Re: RPM issue
that sounds more like an ignition breakdown to me check dist cap and wiresTADTOOMUCH wrote:I meant anything over 2200 rpm and she starts to sputter. at 800 rpms up until about 2100 she seems to run okay. I can't get it to run at all around 3000 or it will run out of gas and quit.
1978 f32
Jim
Jim
- TADTOOMUCH
ignition or fuel
yea, I was also going to do some checking of the distributor, rotor, spark advance to make sure as those items are pretty cheap to replace and check. I got a new marine fuel pump on e-bay for 33 bucks so I thought I'd replace that as well and if not the problem then I'd have one for future.
