Prop size for 1977 F-30 twin screw Chrysler 318
jwc
Post by jwc »
I bought this 1977 F-30 several years ago. Had heads on both engines rebuilt. Max RPMs I can generate is around 3200. My understanding it should max out at 4000-4200. I was told my props may have too much pitch. Does anyone know what the proper size prop should be for a Chrysler 318 on a F-30?
I want to say 14x11 props. What are on there now?
hmc
Post by hmc »
14X10
f boat ( glass )
TROJANS !!!
I belive mine where 14X10 . First two things to check are the tachs and is the bottom and runing gear clean ?
Yep, need some more info. Bottom condition, prop size, mechanical condition of both engines, although I assume, you are getting the same results from both...Just a sliming of growth will effect your speed and rpm.
mr elevman
Post by mr elevman »
mine are 14x11 clean bottom and 4200rpm 72 30' twin 318
wowzer52
Post by wowzer52 »
Clean bottom?
Prop size?
Engine timing?
Forgot to untie from the dock?
1975 F-32 "SIMPLY BLESSED"
