Prop size for 1977 F-30 twin screw Chrysler 318
I bought this 1977 F-30 several years ago. Had heads on both engines rebuilt. Max RPMs I can generate is around 3200. My understanding it should max out at 4000-4200. I was told my props may have too much pitch. Does anyone know what the proper size prop should be for a Chrysler 318 on a F-30?
- Stripermann2
- Stripermann2
Yep, need some more info. Bottom condition, prop size, mechanical condition of both engines, although I assume, you are getting the same results from both...Just a sliming of growth will effect your speed and rpm.
