Zinc for running gear
Have any of you fine gentlemen used Pettit zinc coating spray paint for your running gear? I've read different forums that state you could also use Cold Ganvanized spray paint that has a high amount of zinc in it.?. Speedprop is just way too expensive.
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
' Goomar '
- alexander38
Lord yes it works ! Do your props and shafts. 4 coats each haul out. I hauled in April and the diver found 4 of those d**n white things on my props in September
So...let me get this straight, Guys. You use the zinc-laden galvanized spray instead of traditional zincs OR...in addition to them?
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
"Pettit zinc coat barnacle barrier "
Good stuff 3 thin coats max ( per the can ) I see tony uses 4 w/ no problem . I have very good luck with it . I use a can and half . and I run 22x22 wheels
Good bang for the buck.
Cold Ganvanized spray paint ? not sure how well it will work but the Pettit stuff works great
You still use your normal zincs.
I wonder if it works on zebra mussels ?
No barnacles on lake Ontario, but zebra mussels are in the Great Lakes
http://www.cbyc.ca/
http://www.cbyc.ca/
- alexander38
It's worth a shot. Best 60 bucks I spend for clean smooth bottom. Lord knows the other smooth bottom cost more.
It will keep the barnacles off the trailer for surerossjo wrote:Just ordered (4) 16oz cans ... $60 total.
Wonder how it would work on my skiff's galvanized steel trailer!?
I've used the Cold Galvanizing spray on this trailer. Will take the rust off 1 area and try it on the trailer.
Sure hate to see those people with the Tsunamis in Japan. That would be horrible. 10meters would go up to our 3rd floor bedroom!
