Exhaust risers
Exhaust risers
I've done a few searches but not finding anything... I've got a 6 inch crack in the port side engine and an appointment to get the bottom painted Monday. The question is can it be welded until I can order a new one?
________________________
1975 F-36
1993 Pro-Line center console
1975 F-36
- Stripermann2
As Paul said ...if it has a crack on the outside, how do you know it's not cracked on the inside? The last thing you'd want is for coolant/water to get sucked back through an exhaust port.
Replace it.
Replace it.
- alexander38
no welding, you need a new set sorry to here you've got a cracked one..how did it crack ?
- Sporadic User
