need more advise
antlr-king
need more advise
Post by antlr-king »
im almost ready to pull these old 318's. would you pull them with the transmissions attached? looks like there is enough clearance. also if i unbolt the 2 flages that connect the trans to the shaft this will come apart right?
also what else should i remove before i try to pull this engine out? everything is unhooked and it looks like it will fit up through the whole. then with it out i can remove all the parts i need to save.
also im going to remake the 2 spray rails on the outside of the hull. what type of wood is best. and where can i get the stainless trim thats goes over them. mine is cracked in a couple places and has some rust.
thanks you guys are very helpfull. im sure to call on you some more as i further along this project.[/url]
1979 30' trojan express
Allen Sr
Post by Allen Sr »
I used African Mahogany to make the new spray rails on my F36. Where are you located? I still have a peice left that might make both of yours.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
gettaway
Post by gettaway »
When I pulled my GM 305's, I removed everything that I could get off, minus the transmissions.
Manifolds and risers, alternators, heat exchangers etc. for me it made them lighter and easier to hande.
if you can pick them straight out, Im not sure I would worry
the Transmission coupling should seperate from the shaft coupling, you can push the shaft coupling out just enough to clear when the engines are lifted out.
1984 Silverton 37C
Silver Lining
Scott
larryeddington
Post by larryeddington »
I just disconnecte the electric , water hoses, and pulle all in one power package on my F28. It is whole lot easier taking apart and reassembling the power pack in the shop assuming the room you have is sufficient to pull the enginesl.
antlr-king
Allen Sr wrote:I used African Mahogany to make the new spray rails on my F36. Where are you located? I still have a peice left that might make both of yours.
sounds nice. im in melbourne florida.
antlr-king
gettaway wrote:When I pulled my GM 305's, I removed everything that I could get off, minus the transmissions.
looks like there is just enough room to get them out. i might have to shift a little back and forth while there coming up.
We did one of the spray rails on my father's old '69 many many moons ago... Can't remember if we used mahogany or oak.
antlr-king
larryeddington wrote:I just disconnecte the electric , water hoses, and pulle all in one power package on my F28. It is whole lot easier taking apart and reassembling the power pack in the shop assuming the room you have is sufficient to pull the enginesl.
i hear ya. i got all that disconected on the starboard engine today. gonna do the port side tomarrow. then get with the marina on using the fork lift to get em out. fun fun
larryeddington
Mine was on the hard at farm used my backhoe and two helpers. Set eng on 2X6s on pallets
Piece of cake
Last edited by larryeddington on Sat Jan 21, 2012 9:15 am, edited 1 time in total.
Allen Sr
Post by Allen Sr »
rossjo
Post by rossjo »
Fork Lift or Back Hoe make it nice. Its heavy with transmission attached.
willietrojan
Post by willietrojan »
I used Mahogany to replace the Lower Rub Rails on the Trojan Marlin 25 I had years ago
Spanish Fort, Al
Looking for 33 International
antlr-king
man that real nice. where did you find the stainless trim for those? i need that as well. and where do you find mahogany?
antlr-king
rossjo wrote:Fork Lift or Back Hoe make it nice. Its heavy with transmission attached.
the marina where we are at has a forklift. they will help with the pull out and reset as long as i use 1 of there venders. just so happends a marine mechanic i know is on there vender list.
Allen Sr
Post by Allen Sr »
The stainless was already on the boat and I searched the local lumber companies to see who dealt with exotic woods to find the mahogany.
