here are some specs off the dometic website....
Traveler Self-Contained Toilet / Holding Tank
A complete freshwater toilet system in one self-contained package.
This self-contained toilet/holding tank is a manual toilet and holding tank that can be permanently mounted.
Uses vessel's water supply.
Features:
Freshwater operation eliminates odors
Vitreous china bowl is rinsed with fresh water from on-board demand system
No unpleasant odors associated with a saltwater flushing toilet
Integral anti-siphon vacuum breaker protects potable water supply
Ceramic bowl/plastic base gravity-flush toilet
Self-contained 9.5-gallon (36-liter) polyethylene holding tank
Manual foot pedal toilet operation
Compact seat and bowl
Low-profile toilet model
Uses minimum of 1 pint (.4 L) per flush
Specifications:
9 gallon capacity
1-1/2" outlet to pump out or seacock
20.625"H x 18.875"W x 19.25"D.
Surprise! Guess we need to upgrade the head-advice please!
- aaronbocknek
- classicf25
That is a great trick to know and should be a big help on board, especially on a longer outing. I am not overly thrilled about putting another thru hull in the boat just for the head but I do have 3 old tranducers that are obsolete that could be removed and I could use one of those existing holes. I just hear about the nightmare of thru hull fittings sinking boats and this one will be sitting year round in the water.
- aaronbocknek
well.... sorry, i don't even know your name..... here is another suggestion that some newer boats have as a set up. most newer vessels have a through hull as a discharge as an option. most, if not all, just use a holding tank and deck pumpout set up. what you can do is Y valve the small internal traveler holding tank to a larger one and then dump the waste from the large tank. this can be done manually or via macerator pump.classicf25 wrote:That is a great trick to know and should be a big help on board, especially on a longer outing. I am not overly thrilled about putting another thru hull in the boat just for the head but I do have 3 old tranducers that are obsolete that could be removed and I could use one of those existing holes. I just hear about the nightmare of thru hull fittings sinking boats and this one will be sitting year round in the water.
- lawyerdave71
I agree with Aaron
I recommend the Traveler® 711-M28 Marine Sanitation System the
Complete freshwater toilet system in one self-contained package.
And the link Aaron posted - this is a CHEAP price for the toliet. The prices on these fluctuate at various times of the year. Normally, they are $500 to $600.
Captain Dave -
1978 F30 Flybridge Express
- classicf25
Thanks for all the input. I have all the lines and waste tank ready to go back in tomorrow. Still have to check the existing toilet and get my fresh water system working, however all that seems fairly easily accessible. My big concern was getting the waste tank situation sorted out before the engine goes back in, making it real hard to get to after that. Trying to stay one step ahead of the mechanic and not give any reasons for further delays-lol! We have decided to stay with the existing fresh water rinse system for now and hopefully the rest will go fairly easily. Of course if not I will come to the forum for some more great advice.
Thanks, Lawrence
Thanks, Lawrence
- aaronbocknek
