vibation port side on F32
captron
Post by captron »
I have a vibration starboard side when transmission is in gear and starts at about 1800rpm's. I have anew coupler, shaft, strut bearing, prop's where sent out to be repaired and balanced. I did hit the starboard prop ( not bad ) it all started after that. The hit came about from the starboard transmission cable broke. Wind caught the bow and turn me backwards into shore and hit a rock. The engines where turn off be for I hit. any ideas would be greatly appreciated ..thanks
Reel Easy
Re: vibation port side on F32
Post by Reel Easy »
Well if it started after you hit something its probably a prop or shaft. Disconnect the shaft and put the engine in gear see if you have any vibrations. If not its the shaft or prop.
Dustin
1999 360 Express twin 7.4
Catawba Island, Ohio
The Dog House
Post by The Dog House »
I had a lot of vibration until I had my prop reconditioned. After having the prop reconditioned its very smooth. Most likely the prop needs to be redone.
I agree with both posts above
