vibation port side on F32
I have a vibration starboard side when transmission is in gear and starts at about 1800rpm's. I have anew coupler, shaft, strut bearing, prop's where sent out to be repaired and balanced. I did hit the starboard prop ( not bad ) it all started after that. The hit came about from the starboard transmission cable broke. Wind caught the bow and turn me backwards into shore and hit a rock. The engines where turn off be for I hit. any ideas would be greatly appreciated ..thanks
Re: vibation port side on F32
Well if it started after you hit something its probably a prop or shaft. Disconnect the shaft and put the engine in gear see if you have any vibrations. If not its the shaft or prop.
Dustin
1999 360 Express twin 7.4
Catawba Island, Ohio
- The Dog House
I had a lot of vibration until I had my prop reconditioned. After having the prop reconditioned its very smooth. Most likely the prop needs to be redone.
Former boat: 1971 Trojan F26
I agree with both posts above
