My bow railing is bent on the starboard side along with two of the stanchion supports. I could probably replace those but not sure what my options are for the railing itself.
If I could get another one reasonable priced I would do that since I need to re-bed everything anyway.
long shot... anyone know of a mid cabin parts boat?
Re: long shot... anyone know of a mid cabin parts boat?
Railing is quite easy to come buy. Just (Google) it. Hold on Ill do it for you.BobCT wrote:My bow railing is bent on the starboard side along with two of the stanchion supports. I could probably replace those but not sure what my options are for the railing itself.
http://www.defender.com/category.jsp?pa ... &id=309310
http://www.defender.com/category.jsp?pa ... &id=311487
Trojan
Better yet, why not call Bob for your Trojan parts...I'm sure he can find what you need at a reasonable price. And, you'd be supporting a good cause.
Contact Bob at Beacon Marine Supply -- (609)713-4602
This is true also.Stripermann2 wrote:Better yet, why not call Bob for your Trojan parts...I'm sure he can find what you need at a reasonable price. And, you'd be supporting a good cause.
Trojan
if bob cant help you, you could contact Capt Ross he offered to do some work for largo
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
I didn't explain it very well....
yes, I'm happy to contact Bob, have bought stuff from Beacon before.
BUT, the reason I asked about a parts boat (in addition to some odds/ends) is that the horizontal bow railing is bent inward. Previous owner hit something.
So, I either need to replace it with another one or try and get it repaired/ straightened. It look like one piece and has the curve going up to the bow.
Maybe not, I haven't actually taken one of these apart before.
- ready123
The railing should have small screws underneath where the sections are joined over an inner sleeve. The joint seams often are not clearly visible from the top.
sounds like something that will have to be made, start at your marina and see if there's anyone that does custom S/S work. most likely they'll have to use the other side to match it up.
