Vacuum Flush System ?
Reel Nauti
Post by Reel Nauti »
Hey all, the holding tank on my boat came with a nice crack in it. I tried plastic welding it last year along with a whole ton of other goops placed on it with nothing sealing the deal.
I am looking to replace the holding tank with just a normal tank with out the macerator. Since I do not/can not use the thru hull disposal on it I will just be setting it up for pump out.
My question is can I put just a normal waste holding tank in with a vacuum flush system? Is there a difference in the density of the plastic/resin?
1989 10 Meter International
Twin 454 Crusaders
"Reel Nauti"
rbcool
Post by rbcool »
Shouldn't be a problem. Just make sure you properly vent it.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Reel Nauti
Thanks for the reply RBcool, just can't justify spending another $700 on the Sanex replacement tank when a basic box one will do.
Twin 454 Crusaders
"Reel Nauti"
Peter
Post by Peter »
one of my boating buddies ( yes...I have friends :roll: ) had the vent plug up on his holding tank with out knowing it ( on his 42 pacemaker).Any way, while working on the problem, his holding tank split, spewing ...uh....holding tank contents... all over him and the bilge....uhg....yuck...funny now though hee,hee,hee.
Please insert acceptable political or boating statement here...or not... I really don't give a crap....
LandVF36
Post by LandVF36 »
Most vacu-flush systems have a vacuum tank that is a small 1-2 gal capcity, then a macerator pump that moves the waste to a larger holding tank. If this is the type you have, then any holding tank will do.
I've got a few good deals from http://www.tank-depot.com over the years.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
Reel Nauti
Thanks LandV, this is indeed the set-up that I have, I will check out your link. Boat upgrade season is just around the corner :wink:
Twin 454 Crusaders
"Reel Nauti"
