Heat Exchanger
fourreins
Heat Exchanger
Post by fourreins »
I will be replacing the rubber end caps on the heat exchanger and was curious if you need sme type of sealant on them.
No sealer need or recommended . with that said if the surface is in poor condition a thin coat can be used . But if in good condition use only the gasket or seal
fourreins
Post by fourreins »
thank you!
rbcool
Post by rbcool »
Both Mercruiser and Crusader recommend using a sealant. Here's a quote from Crusader that is identical to Merc
1. Remove the bolts securing the heat exchanger
end plates. Remove the end plates and gaskets.
2. Clean the water passages in the heat exchanger
by inserting a suitable-size wire brush into each
passage. Use compressed air to blow out loose
particles.
3. Clean the gasket surfaces on the end plates and
the heat exchanger. Apply PerfectSeal to both
sides of the new gaskets. Install the end plates
and the new gaskets onto the heat exchanger.
Install the bolts and tighten securely.
4. Start the engine and inspect for leaks.
Personally I've always used a very thin coat of grease to almost any wet location gasket.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
My books say different , but what ever you do Don't glob it on , if you put anything on put it on thin .
fourreins
Post by fourreins »
Perfectseal??? Where can you buy that? You mentioned you use thin coat of grease...what type of grease?
rbcool
Post by rbcool »
I would try Bob @ Beacon here. If they don't have what you need try this :
Marineparts.com
GASKET SEALING COMPOUND, 4 OZ.
"Replaces: Mercury 92-802881A 1, 92-34227 1 (Perfect Seal), OMC 317201, 508235 (Gasket Sealing Compound). A slow drying, non-hardening brush-top sealant. Gasoline, oil and grease resistant.",
SKU: 47-37559
Price: $8.35
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
I did find PerfectSeal listed in some of my gas books , however looking at my Diesel info nothing is shown .
Almost eveyone I have seen leaking had lots on sealant on it . So don't over do it .
I will keep doing dry
Wet , dry. How about a little silicone compound and call it quits. And leaving the rubber dry can hurt. :lol: :lol:
silicone as in RTV No way
Compound !! Not rtv, compound is a silicone lube non-harding Navy uses it to keep rubber gaskets soft and pliable, can't use rtv on heat exchangers it could get in the tubes.
rbcool
Post by rbcool »
Well how about 5200 :lol: :lol: JUST K I D D I N G :roll:
In all honesty...... on that type of gasket I usualy use a lube, then wipe it off with my fingers. Keeps the gasket supple, holds it in place while installing, and I have never seen a leak. Ditto on raw water pump gaskets at the inspection plate.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
5200 ! :twisted: this is clearly a place for Homer home owner tub and tile off white sealer RTV. :lol: :lol: :lol: and yes I'm a smarta$$
I will be nice I will be nice I
Allen Sr
Post by Allen Sr »
prowlersfish wrote:I will be nice I will be nice I
BITE THY TONGUE'S :wink: :lol: :lol: :lol: :lol: :lol:
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
