intake water screen/filter
- guglielmo6160
what do you guys think of the filter to screen the intake raw water to the raw water pump,
I have one, that was supplied to me with the boat, but have had boats without.
for obvious reasons if your in a dirty environment Im assuming its a good idea
just some thoughts on it,
opinions etc
opinions etc
1983 10 meter express
Witch screen are you talking about to be clear ?
- guglielmo6160
Yes you need that.
- guglielmo6160
Got a name on it. And it should be a O-ring.
You really need it - I've seen it save a 900HP Lugger when we ran over weeds 50 miles offshore ... just pulled the basket, cleaned the weeds, and we were back on the go.
- guglielmo6160
- Location: Mt Juliet, TN. Percy Prist Lake, Fate Sanders Marina
What is the manufactures name? Tell us, do a Google search on it. Last fall I had an overheat problem, and the impeller blades were shot in the raw water pump whick draws the cooling water diectly from the lake (no strainer). Found out about strainers then and before our boat leaves the slip this year, it will have a strainer installed.
Larry
Larry
- guglielmo6160
