Has anyone found a better gasket set for chrysler small block aluminum oil pans?
Valve cover gaskets are available in rubber with steel inners.
For pans maybe?
Alternative to cork pan gasket.
- Paul - SW Ontario
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
Re: Alternative to cork pan gasket.
I can't say I've seen anything like that for oil pans.Paul - SW Ontario wrote:Has anyone found a better gasket set for chrysler small block aluminum oil pans?
For pans maybe?
I may be wrong, the reason valve cover gaskets are rubber is so they don't have to be replaced every time a cover comes off, I don't think you'll find them for oil pans
Barrie
Aylmer Ontario, Canada
36' Tri-Fly "The Obvious"
Paul check out summit racing ,there are a lot of choices for these engines...I still like the cork though, the rubber can be a bit of a problem if the pan is not torqued just right, imo..Mr gasket had the ultra seal or some name like that, that we always used, great for valve covers on and off many times and no leaks......MikePaul - SW Ontario wrote:Has anyone found a better gasket set for chrysler small block aluminum oil pans?
For pans maybe?
