Home ☰
Chrysler Parts - Raw Water Pumps
D55 - Large Impeller -- 43.38
The D55 takes two different size impellers a small and a large. The D55 was used on the Chrysler 383, M400 and the M440. If unsure which pump you have -- call 609-713-4602
D55 - Small Impeller -- 43.39
12 Blade Impeller Kit -- 43.37
Part Number: TRJ9959K - The D60 takes two impellers - Both same size ** requires two kits **
G7B Chrysler Single Impeller Pump -- 187.78
G7B Chrysler Single Impeller Pump -- Major repair kit -- Sherwood raw water pump major repair kit for raw water pumps used on Chrysler engines from 1975 to present. Includes impeller, seal and seat, bearing, wear plate, cam, retaining rings, key, O-ring and end cover gaskets
Sherwood Water Pump Cam -- 75.80
Sherwood Water Pump Cam (D60)
Part Number: TRJSH15883
G7B Wear Plate -- 41.50
G7B Wear Plate -- Only ONE Available
12 Blade Impeller Kit -- 43.40
Part Number: TRJ10615K - This is for all Chrysler Single impeller pumps.
Cam - Large -- 75.91
Cam (large)
Used on Sherwood D55, 383, 400, 440
Part Number: TRJSH10944
Sherwood G7B -- Reconditioned -- 451.99
Sherwood G7B -- Reconditioned -- New bearing -- New seal -- New cam -- New impeller
Raw Water Pump -- 617.47
Sherwood Raw Water Pump -- Part Number: TRJSHG7B
Cam -- 95.86
Cam - (Sherwood Raw Water Pump -- GB7)
PART #TRJSH10929
Raw Water Pump Pulley -- 103.23
Used in 318, 340 -- 3/4" Shaft
Also for 383, 400, 440
Part Number: TRJ26598701
Raw Water Pump Pulley - 5/8" -- 102.00
LM318, 340, 360 with 5/8" shaft
Part Number: TRJ28476281
Pulley Retaining Clip -- 2.89
Part Number: TRJ6024440
