Home ☰
Trojan International -- Hardware
671 Owners Manual -- 229.12
671 Owners Manual (copy)
Crusader Service Manual -- 127.00
Crusader service manual covers all carburated 350 V8 and 454 V8 as well as the V 6 GM Crusader engines from 1980 to 1992. This **does not** cover any EFI, TBI, or MPI equipped engines.
VDO ADIS 360 Manuals -- 50.00
VDO ADIS 360
Installation and operation manuals (both)
1990 Original Int'l Catalog -- 45.00
1990 Original International Catalog
All boats - 24 color pages
Lunaire Maintenance Manual -- 35.00
LunAire Manual with electrical drawings - 30 pages
City Water Pressure Regulator - (45 degree) -- 52.49
City Water Pressure Regulators with 45 degree pipe fitting. 45 degree pipe fitting Fitting turns 180 degree or any angle connections.
City Water Pressure Regulator - (straight) -- 54.59
Trojan Pressure regulator -- Replacement for original regulator with straight connection.
Anchor Hatch Lock -- 49.02
Int'l Anchor Hatch Lock
1 3/4" x 1 3/8"
Chrome Plated Drawer Pull -- 17.20
** Only THREE Available ** Width overall 3 7/16" -- Width inside 2 5/16"
Hatch Hinge -- 59.17
Hatch Hinge
For Trojan white Plexiglass flush deck hatches -- 3" x 1.5"
Hatch Latch -- 68.11
Hatch Latch - Stainless Steel for flush deck Trojan hatch. This latch was used on the early 1982- 1983 Internationals. Might work on latter years but would probably need to be shimmed.
Hatch Openers -- 189.34
Hatch Openers -- Int'l Series
Hatch openers for International series boats. Chrome plated -- NEW! -- Only ONE available!
Round Hatch Pull -- 19.77
Round handle International hatch pull
Speaker Volume Control -- 65.00
Speaker Volume Control -- Replacement for International Series volume control
Square Hatch Pull -- 18.60
Trojan Hatch Pulls
3" by 2 1/4"
Trojan Flush Ring Pull -- 18.89
Chrome Plated Bronze -- 1 5/8" Face plate
Scupper Drain -- 67.91
Scupper Drain -- Drain Fitting - 3' -- 3.63 in. Long -- 3.00 in. Deep -- White only
Sliding Window Locks -- 19.87
Sliding window locks
Vent Window Motor (11M) -- 145.03
Vent window motor for 11 Meter - This is a new motor which is wired up with a new diode.
Vent Window Opener
Vent Window Opener
We can rebuild your vent window opener. Comes with new cover motor and related parts as needed. Call for pricing.
Window Vent Arms - 12M -- 30.49
12 Meter Side Window Vent Arms
Part # 12MTRJTAY11616 - Sold as a *Pair*
Window Weep Slot -- 17.77
Sliding salon window weep slot covers
Silver Color -- 8.5" Long
Window Weep Slot (Black) -- 19.67
Black Color -- 8.5" Long
Trim Tab Cylinder Bracket -- 21.60
Cylinder Brackets are used on the top and bottom of each hydraulic cylinder. Comes as seen in picture. ** Four available **
Trim Tab Cylinder Pin -- 1.68
Trim Tab Cylinder Pins -- Nylon cylinder pin
Trim Tab Cylinders -- 279.26
Trojan Trim Tab Cylinders
$279.26 for the pair comes with hydraulic line ** Cylinders and hoses only ** (transom and tab brackets are sold separately)
Trim Tab Hose -- 5.64
Trim Tab Hose
Designed and manufactured exclusively for Trojan Boat Leveler. This trim tab hose is Rated at 2000 lb. burst pressure. Sold per foot -- Enter number of feet in Quantity
Trim Tab Hose Cover -- 24.61
Trim Tab hose cover (with screws)
Trim Tab Motor Pump -- 375.60
Trojan trim tab motor pump. This 12v motor pump can be used to replace the Trojan trim tab pumps in all single cylinder, 12v Insta-Trim systems. For use in both F-Boats or International. This pump unit comes with a housing, reservoir, motor, pump, solenoids and brass hose fittings and 2 stainless steel hose clamps (already assembled). This allows for easy installation
Trim Tab Pump Reservoir -- 76.45
Trim Tab Switch -- NEW -- 168.00
Boat Leveler Tab Switch -- NEW
Trim Tab Switch Plate -- 32.13
Blower Vent -- 2.5" -- 12.56
Blower Vent -- 2.5" -- Aluminum vent used on Tri-Cabin Tri-Fly and some Internationals.
Seat Bracket - Folding -- 120.00
Used folding aluminum seat bracket
** Only TWO available **
Trojan Seat and Back -- 45.00
Trojan Seat and Back (fabric)
For folding wood captain chair. When installed over the frame seat is 18" wide and back is 16" wide. Giving a 3" pocket on each side for the back supports and 2" on each side for the side support. Size : Seat 22L x 15.75W - Back 22L X 6.5W - Made of heavy boat canvas
Trojan Stern Flag Pole Holder -- 24.89
Trojan Stern Flag Pole Holder (3/4")
Trojan original Stainless Steel stern flag pole holder (USED)
Morris Handle - Black -- 33.73
Modified TeleFlex handle to fit Morris Control - We recommend buying in pairs so that both handles match (price shown is for a single handle). If you are unsure if your control is a TeleFlex or Morris control please call, text or email us and we will help you identify your control.
Morris Handle - Red -- 33.77
Morris Handle - Red
Modified TeleFlex handle to fit Morris Control. We recommend buying in pairs so that both handles match (price shown is for a single handle). If you are unsure if your control is a TeleFlex or Morris control please call, text or email us and we will help you identify your control.
TeleFlex Handle - Black -- 23.73
TeleFlex Black Handle
If you are unsure if your control is a TeleFlex or Morris control please call text or E mail us and we will help you identify your control.
TeleFlex Handle - Red -- 23.77
Red TeleFlex Handle
Deck Fasteners / Knobs -- 13.75
Deck Fasteners / Knobs -- International
T-Handle -- 41.20
T handle - ONLY for emergency stop
** Only FOUR Left **
T-Handle - Emergency Stop -- 133.79
Emergency Stop T-handle Kit
Chrome-Plated Fill Cap -- 63.82
Chrome plated 1 7/8" fuel fill cap
All Trojan used one of two different fuel fill caps this is the Chrome Plated Bronze for a 1 7/8" fill. The other was a solid stainless steel cap. The stainless steel fill cap has a back which is solid not like this cap which is hollow. If you need a fuel cap and the back is hollow like this cap this is the one you need.
Gas 'O' Ring -- 9.75
Gas 'O' Ring
For all Trojan stainless steel gas fills
(S/S Fuel fill cap has solid back to the inside of the fill cap)
Waste Fill Cap -- 189.76
Waste Fill Cap (comes with O-ring) -- Chrome plated bronze - Top of cap measures 1 15/16" -- Note: Only ONE available -- No Longer made.
Line Chock -- NEW -- 269.00
Line Chock -- 8"
Used on F Boats - One pair only
Trojan Hollow Base Cleat (10") - (USED) -- 87.63
Hollow Base Cleat - 10"
USED - Stainless steel: 10" Long x 2.25" High - Under Side Mounting - 1/2-13 Threads - Use Studs (Lock Tight) or machine bolts (excluded) - Most Trojan cleats have 3/8" - 16 tapped holes
AC Generator Control Plate -- 142.73
AC Generator Control Plate -- Have 3 available
Fuel Control Board -- 48.19
Fuel Control Board
** Only 10 available **
Trojan Oil Placard -- 19.74
Trojan Oil Discharge placard (metal)
#TRJ14-78220A - New old stock
Swim Ladder Steps - Teak -- 52.00
Teak steps for Trojan swim ladder... Price is for each step...
Swim Platform Brackets
Swim Platform Brackets -- Only FOUR Available -- Price: $115
Swim Platform Bumpers -- 37.17
Swim Platform / Ladder Bumpers
Sold as a pair
Swim Platform Latch -- 48.29
Trojan T-handle Swim platform (ladder) Latch
** Only THREE available **
Wiper Arm
Wiper arm
Used on all Trojans - F-Series and International -- These wiper arms are not available elsewhere. Price is for one wiper arm.
Wiper Blade - 16" -- 24.67
16" Trojan Wiper Blade
Used on all Trojan boats
Wiper Cover Base -- 57.69
Wiper Cover Base
Generally the wiper cover base is reusable. If you find when removing the plastic cover that the base is broken then order this base when ordering a new fiberglass cover.
Wiper Motor -- NEW -- 251.40
Wiper Motor -- NEW
New wiper motor for both F-boat and International Series
Wiper Motor -- Reconditioned -- 150.40
Wiper Motor -- Reconditioned -- Used on all F-boats and International Trojans
Wiper Motor Cover (Int'l) -- 103.64
Wiper Motor Covers
Wiper motor cover for International Trojans. This is a direct replacement for the original plastic wiper cover made by Trojan. Cover is fiberglass and gel coated white.
Snap Cap Bases -- 9.00
Snap Cap Bases
Sold in bags of 10
Snap Caps -- 9.00
Snap Caps for Interior Finishing
Colors: Red, Burgundy, Tan, Off white, Silver, Light blue, Dark blue, Dark brown, Light brown, Light green ** Sold in bags of 10 -- Indicate color at checkout
Bilge Blower - 3" -- 188.06
Bilge Blower 3" (flange mount)
Part #TRJ 347390010 - 150 CFM - 6.5 amps, 12VDC - 4450 RPM. Designed for non-continuous duty applications
Bilge Blower - 4" -- 230.03
Bilge Blower 4"
250 CFM - 12 amps, 12VDC
Hose Flange - (Twist-On) -- 12.86
Twist on 3" hose flange
Allows topside hose installation with no clamps - Non corrosive plastic - 3 1/2" installation hole - Pre-drilled for 3" #10 screws.
Teak Trim / Molding
Teak Trim / Molding
We have lots of small trim, frame, edge and unusual shaped pieces of teak. No large boards. Call with size needed and we will check -- 609-713-4602
Prop Nut Kits -- 49.42
Prop Nut Kits
Please tell us the type of Trojan boat you have. Enter the year of manufacture and engine type (in the Comments box) when checking out. If you're not sure -- the hull number will work to ID your boat.
11 Meter Exhaust Valve -- 48.63
11 meter exhaust valve
13M / 14M Helm Pump -- 1,470.00
13 // 14 Meter Helm Pump
New -- Hynautic helm pump -- Part# TRJH-41-02 -- 2 units available
Anti-Siphon Valve -- 35.27
Anti Siphon Valve
3/8 MNPT x 3/8 MNPT - Used on all Trojans from 1977 - 1992 to prevent siphoning of fuel tanks if a fuel line leaks or breaks
Bumper - 1" -- 14.89
1" inch bumper was used in several applications on all Trojans. One notable place was the support for the dinette table when lowered for a bed.
Cockpit Stair Catch -- 59.49
Cockpit Stair Catch
59.49 for a package of two (sold as a pair)
Curtain Carriers -- 10.00
Trojan curtain carriers (eyelet style)
$10.00 for package of 10 pieces.
Curtain Rod -- 5.85
Curtain Rod / Slide Track
Plastic slide track -- Have 32 feet -- (sold per foot basis) -- (Enter # of feet needed in Qty) -- Longest length 8’ -- Just the curtain rod - NO Eyelets
Double Sink -- 260.00
Double Sink - S/S
For F Boats and Internationals - 23" L x 15.75" W x 5" D
Draw Latch -- 12.49
Draw Latch -- Draw latch used on push button dash panels
Engine Room Ladder -- 260.00
Engine Room Ladder - NEW
International 14 meter (all years)
Exhaust Collector - T-type -- 168.63
Exhaust Collector - (T-type)
Buck Algonquin TRJ40EC30400B - Powder-coated gray iron - Finish: Powder Coated, Material: Cast Iron, Hose ID: 3", ID: 3", ID: 4", Dimensions: 7-13/16" x 6-1/4"
Exhaust Collector - Y-type -- 187.46
Powder-coated cast iron 'Y' exhaust collector - Finish: Powder Coated Finish, Material: Gray Iron, Hose ID: 3", ID: 3", ID: 4"
Exhaust Elbow - 90 deg -- 98.75
Exhaust Connection - 90 Degree Elbow
Powder-coated cast iron - Finish: Powder Coated Finish, Material: Cast Iron, Angle: 90° Hose OD: 3", Dimensions: 4-1/2" x 4-1/2"
External Eye End -- 8.00
External Eye End
1" OD -- Stainless steel Have 10 $8.00 4 oz
Fender Rack -- 450.00
Powdered Coated Fender Rack
10 meter medium cabin express and late 11 meter express -- 24" long // 16" deep // 16" tall
Groco Arg 750 -- 177.90
Groco ARG 750 3/4 NPT
New Old Stock -- Comes with the Metal Screen and Polyethylene basket
** Only ONE Available *
Groco Neoprene Gasket -- 9.00
For the Groco SV 1250
Groco SA Service Kit -- 34.57
Service kit for Main engine vintage Groco SA strainer -- 1.25"
Groco Strainer Service Kit -- 21.00
If your Trojan main engine strainers look like this then you have the new style (1250) 1.25" strainer. This is the service kit for the new 1250 strainer.
Groco SV-1250 (90 deg tailpiece) -- 69.70
** NEW** 90 degree tailpiece 1.25" for SV-1250. Tailpiece comes as seen with a NEW gasket.
Groco SV-1250 Valve (Reconditioned)
Price: $185.00 -- There is a $60.00 core charge. When a complete and serviceable core is returned we will refund your $60.00 core charge. ** MUST call to Order **
Groco SV-750 Valve (Reconditioned)
Price: $165 -- Reconditioned Groco SV-750 valve -- Core charge $60.00 ** Must call to Order**
Head Sink -- 89.43
Head Sink
Oval -- 10.5" x 13.5" -- 5" deep ** Only ONE Available **
Heat Exchanger End Plate (4") -- 32.04
Heat Exchanger End Plate - 4"
4” End plate gasket kit. Comes with bronze end plate, gasket and hardware.
Heat Exchanger End Plate (5") -- 71.53
Heat Exchanger End Plate - 5"
5” bronze end plate for exchanger - Comes with gasket and hardware as seen in photo.
Hull Plug (with O-ring) -- 20.00
Hull plug (with O-ring) -- Fits all International boats
Int'l Vacu-Flush -- 50.00
Trojan International Vacu-Flush
Dometic white Bellows S/T Pump (385230980)
New - Have one only
Jaw Slide -- 9.14
Jaw Slide
1" OD tube -- stainless steel
Lounge Table Leg - 12M Express -- 58.45
12 Meter Express Lounge Table Leg - New - Length: Approximately 14" long
Mid Cabin Lock Set - Original -- 145.61
Mid Cabin Lock Set - Original -- Only ONE available
Paddle Latch -- 46.25
Trojan Paddle Latch
$46.25 each
Perko Engine Strainer Gasket Kit -- 32.25
Perko Engine Strainer Gasket Kit -- 1.25" engine strainer gasket kit rubber -- Only ONE available
Perko Strainer Gasket Kit -- 28.25
Perko Strainer Gasket Kit -- Used on AC supply raw water and generator raw water 3/4 supply hose
Perko Strainer Kit -3/4" -- 27.97
Perko Strainer Kit -3/4" -- Cork Gasket -- This strainer was used on the AC and Generator supply of raw water
Quick Release Step Pin -- 59.10
Quick Relese Step Pin ** Only TWO available **
Rail Bases - 30 deg -- 30.00
International Rail Bases - 30 deg
30 degree
Rail Bases - 90 deg -- 30.00
90 degree
Shift / Throttle - Int'l -- 498.71
Shift and/or Throttle
Direct replacement for Trojan International control. Please state which control Shift or Throttle. If you have a Morris Control -- we can provide a template to assist with installation. If you have a diesel -- you may need a neutral safety switch. It may be best to call before ordering... Bob -- 609-713-4602.
Swim Brackets (11M) -- 880.00
Swim Platform Brackets for 11 Meter
Two outside // Two inside -- ** Brackets are New ** -- 24" x 18" x 6" package
T-Rail Lock -- 95.00
Mechanical T Rail Lock
** Have 15 total **
T-Rail Wrench -- 20.00
Mechanical T Rail Wrench
** Only have 4 **
Trojan Fletch Lock -- 27.50
Trojan Fletch Lock for Internationals
Star Handles - ABS -- 12.73
ABS Star Handles
** Have 10 handles **
